SierraMark
- Feb 27, 2012
- 135
This is strange....
Yesterday I went out to the boat, which is stored right next to my garage. I have not used the boat in about 3 weeks and to prepare for an upcoming trip I wanted to make sure the motor was good so I hooked up the muffs and started the motor. It started right up but no pee stream so I kill the motor and go look at the tube and I see pieces of grass and other stuff coming out of it. I pull the stuff out and turn the motor over again now the water is dripping out but not a stream like it usually is. I take the tube off the engine and clean out more stuff...now the tube is completly clear so I hook it up and start the motor again and it is dripping a little more but still no stream. I take the tube off again and there is more stuff in it so obviously the stuff was in my engine and it came out. I cleaned the tube again and started again and this time the water was streaming as it should.
Looking at the stuff that was coming out it looked like pieces of grass that were kind of twisted together...looked like maybe a bee's work but no bee's came out of the tube or were around the boat.
Has it happened to anybody else?
I am thinking my solution is to cover the hole and remove the cover before going out.
-Mark
-Mark
