Gray colored lower unit oil
Captengine44
I have a 90hp 1995 Mariner. When I checked the lower unit oil today it was silver colored. <br /> When I bought the boat last year the oil was thick and gray. I replaced it and checked it after a few times out and it was milky colored, so I had the seals replaced. When I changed the oil this spring it was it was ok(tea colored).I have a bad feeling about this. Any feedback would be appreicated. :confused:
werdna
Re: Gray colored lower unit oil
the LU drain plug should be magnetised. is there any small metal filings on it???
The Marine Doctor
Pop the Brg carrier out of the gearcase and have a look inside.<br /><br />This will eliminate any guessing<br /><br />TMD
BRIAN03
Water got in the lower unit and there is a bad or bad bearings.
D
DJ
Guest
Captengine44,<br /><br />Lower units are pretty simple and tough. They can withstand a little water ingestion and not be hurt. The trick is to not let the water sit in the L/U for any length of time.<br /><br />The most common point of water intrusion is the fill/drain plug seals/gaskets. They should be replaced every time the plugsare removed for service. <br /><br />If you are storing your boat for the winter, drain and refill the L/U, replace the seals and check it next spring after your first run.
