TheCat1212
- Feb 28, 2013
- 26
Good morning. I have a 1986 25hp merc. Over the week end, after a very short run, I noticed a silvery, gray sludge leaking from THE MIDDLE of the prop. I had just de-carbonized the motor as well as just changed the lower unit gear oil. My first thought was a leaky screw in the lower unit or a seal behind the prop. Then I realized it was coming from the middle. When I removed the 1 hour old gear oil, I DID NOT see any water intrusion into the oil. Is it possible this is from the decarbonization? Or do I just NOT know what to look for. I drained the lube into a clear jar and zero water settled out of it. What else in the engine could cause this? Please!
