Grease Fittings for Gimble Bearing-470mercruiser
buymorecoffee
Can you tell I'm new at this? Are the grease fittings for the Gimble Bearing the ones that are visible on the outdrive-back of the boat? Any grease fittings anywhere else other than the out-drive, trailer of course, that need regular attention?
Don S
Re: Grease Fittings for Gimble Bearing-470mercruiser
Get the Mercruiser service manuals for your particular engine and outdrive, it will show all the lube points.<br /><br />
hoot
great picture post DonS. BMC, your trailer wheels should have grease fittings on the outside, in the middle of the spindle. A good marine water resistant grease should be used here.
buymorecoffee
Thanks, I do have the service manuals, your picture seems to be pretty acurate to my boat, I have buddy bearings on the trailer wheels-so I'm good there.
crazy charlie
Don,I have never seen The zerk (d) .What is it for????I have never had one.Charlie
Bt Doctur
the upper and lower zerks have been eliminated on later models.A & D
