Grease Fittings
Scode68
Are the grease fittings made of stainless steel or are they just like on an automobile? Have a 1996 90hp V4 and one of the grease fittings I can't get any grease through.
Boss Hawg
Re: Grease Fittings
Have no idea if they are the same but no matter - if you cant get grease thu it change it -
Scode68
Re: Grease Fittings
Thanks,
I never gave it any thought before but it was working. I wasn't even sure if they made them that way but I see you could get them made just about any way you want.
Just figured that I use the boat in salt water only and thought SS made the most sense.
F_R
Re: Grease Fittings
Well, there was a year that OMC used some steel (car) fittings and it created a huge yowl. Almost as bad as the time they used pressed-in fittings and they all came out when you tried to pull the grease gun off of it.
Let's just say they are supposed to be stainless.
Scode68
Re: Grease Fittings
Thanks,
I'll see if I can clear it out if not its off to the OMC guy.
Tim Frank
Re: Grease Fittings
Every stuck grease fitting that I have suffered has yielded to a rap on the little ball with a small punch. The impact has always freed up the little ballbearing and the fitting has then taken grease. You don't need much "oooomph".
Mas
Re: Grease Fittings
Might want to take it off and soak it in some solvent. I cannot imagine that they would go bad...just some crap in it. Might save you a couple of bucks and a trip to the MAN.
MAs
GA_Boater
Re: Grease Fittings
Zapper - Stop selling your tool in old threads.
