Grease out of the starboard exhaust hole ??????!!!!!!
sarantis
What else i'll see! After having checked the new engine and before starting the antifouling painting i saw something that terified me .Can anybody tell me where did that grease come from???
MCM228 (year1978 pre-alpha outdrive)
gm 305(2piece rear seal ) to 350(1piece rear seal) swap
ziggy
Re: Grease out of the starboard exhaust hole ??????!!!!!!
looks like new 2-4-c grease to me. right down by the lower pivot point of the gimble housing (gimble ring) that gets 2-4-c for pm. did ya grease that lower pivot with a lot of grease? when i grease mine there i can see the old grease and new come out of the pivot as the new is pumped into the zerk... maybe just over greased?
sarantis
i put a lot of grease everywhere but i can't understand which is the point you are talking about.What i' m afraid of is the gimbal bearing area because there are signs of corrosion there but it seems to be far from the exhaust hole.
ziggy
in s/m #4, pp 1-6. under lubricating swivel pin and hinge pin. letter D is the lub point i'm refering too. the bottom swivel pin. the pin that allows the gimble ring to pivot port to starboard, that allows you to steer the boat.. the bottom pin specifically...
sarantis
ok i almost understand but how can the grease gets into the exhaust?
Bt Doctur
If your referring to the 2 holes on either side, there exaust reliefs, and there should be no grease coming out from there unless someone put it in there.
sarantis
you consider it imposible to have any connection internally with the lubricating passage of the gimbal bearing?
