Grease Seal to Spindle Fit
Weirthit
I recently replaced a warped rotary hub on my tandem axle trailer. Went ahead and replaced the bearings since the cups were pre-installed in the hub, and replaced the grease seal. On the first tow, all of the grease in the bearing buddy blew out of the new rear seal. The seal I.D. is 1.686" and the spindle diameter where the sleeve rides is 1.677 (measured with dial calipers) so no surprise is leaks.
I found a grease seal with an I.D. of 1.62", at least 0.050" smaller than the spindle diameter where the sleeve rides.
Is 0.050" interference between the grease seal and spindle too much? I would hate to destroy the seal surface.
Thanks for any feedback,
Brian
bruceb58
what is the seal number you are using that is too big?
You probably need a 470460, assuming the outer diameter is standard.. That was the seal I used for my axle spindle which is the same size as yours. That number is the same for bot Timken and National.
I am guessing you are currently using a 473336 which is too big,
dingbat
As an alternative, I switched over to a 16735.
The 16735 has a rubber cased, one piece seal designed for power transmission applications, ie. gearboxes, motors, speed reducers, etc.
Overkill for grease filled hubs, but the rubber case helps with any misalignment issues and allows them to be removed and reused after bearing inspection, if desired.
Weirthit
Thank you for the response.
The seal that was leaking is a 168255TB. Same as 470460 per the Timken Federal Seal Catalog.
I also checked the Timken Federal Seal Catalog and the 470460 is for a 1.687" shaft, 0.010" larger than the seal area on my spindle which is 1.677".
I am wondering if the seal with a 1.62" ID is too tight for a 1.677" OD seal area.
Also wondering if I have a mis-machined spindle. Wouldn't be the first thing wrong with this VM Trailer.
