Grease tilt tube
johninmo
I have a grease zert on my tilt tube and was going to grease it nothing wrong with it just routine maintence but wasnt sure what grease should I use I have some regular automotive grease in my grease gun now is there anything wrong with using it
Thanks
Chris1956
Re: Grease tilt tube
You may use any grease. It is just a dumb bushing. I use boat trailer wheel bearing grease for everything. It is salt water resistant, and is good for chassis, bearings, bushings and most anything else.
johninmo
I didnt know if it was supposed to be marine grease or something else is all thanks
j_martin
You should use marine grease for all applications on the outboard. I have a small grease gun loaded with marine grease for the engine and trailer wheel bearings.
If you have dual cable steering, and there's a grease zerk on the front tube, DON'T grease it. (ask me how I know)
hope it helps
John
