Grease - Yoke, Spline, engine coupler, gimbal bearing
g_speran
Hello ALCON,
I am getting ready to reassemble my out drive back onto the gimbal housing; but before I do so, I want to regrease everything (Yoke, Spline, engine coupler, gimbal bearing, etc). Is it necessary to make a 50 mile one way trip to my "local" boat store and get gimbal grease, spline grease, etc, etc; basically getting each individual grease for each specific application or would it be ok to make a 5 mile trip to my local WalMart and get Marine grease. I also have AutoZone, AdvancedAuto, and O'Rileys available. But I look for the experts answers and recommendations.
Thanks
Gary
Super Tech Marine Grease, 14 oz
Super Tech Marine Grease is a state-of-the-art lithium complex grease. This tacky grease resists water washout even under the most severe saltwater conditions. It offers superior protection against rust, corrosion, and oxidation.
Super Tech Marine Grease, 14 oz:
•Premium multi-purpose marine grease
•Melting point of 500 degrees Fahrenheit
•Can be used for wheel bearings
•Made in the USA
http://www.walmart.com/ip/Super-Tech-Marine-Grease-14-oz/16928008
MarkSee
Re: Grease - Yoke, Spline, engine coupler, gimbal bearing
You're likely going to get varying opinions but I only buy and use exactly what is recommended for the various parts of my boats:
1-u-joint and gimbal bearing
2-engine coupler and spline
3-24c
4-special lube 101
Not to mention: Perfect seal, bellows adhesive, Merc 25-40 oil, Merc hi-po gear oil (now that's cheaper at Wallyworld)
I just look at it as so many different things can go wrong anyway (especially for us rookies doing our own service) why not use the recommended stuff so that's not a variable?
Mark
Hello ALCON,
Thanks
Gary
•Made in the USA
Ayuh,.... See below,....
V
V
V
V
V
V
V
V
V
V
V
g_speran
Bond-O,
I has suspected that if you replied, that would be your response since it is part of your signature :) . Just looking to do it right the first time. This is why I ask the experts on this forum :) .
Thanks,
Gary
Don S
Then use the OEM stuff that is called for by the Manufacturer. Everything after that is a personal choice.
Keep in mind, Merc has to warranty their product, so the test an recommend what works best for their product so they don't have to pay to fix it when something breaks.
