Rocky_Road
- Oct 8, 2008
- 1,798
I have my grease gun loaded with the Quicksilver gimbal bearing grease...but there are also several hinge pin fittings that need to be greased.
Do I have to go to the trouble of buying a second grease gun (and correct hinge pin grease)? Or can I just give the hinge pins a shot of gimbal bearing grease...and be done.
Second question...how do you know how much gimbal grease to use? And, if you overgrease...where does it end up? Can too much gimbal grease create a whole new problem?
