greasing u joint alpha 1 - new grease only came out one cap
zellerj
I have a 5.7 L alpha 1 and I recently pulled the drive to service the water pump. I was greasing the U joint and the forward joint greased fine. Howeve, for the rear joint, I noticed that the grease was only coming out of one arm of the rear U-Joint. I could not get the grease to push through the other caps. I even applied some heat with a heat gun hoping to thaw out old hardened grease, but no go. I gave up and installed the drive anyway, because the U joint appeared to work just fine and was not rusty or stiff. How important is it to push the new grease out through the end caps?
alldodge
If it feels good, then its like water flows the path of least resistance. If one cap is weak, then this is were it will leak out. When greasing watch the joint and pump slowly. You should notice the cross move a bit. I thing your good
