Greasing universals on Alpha1
TooTired
Is this a easy task to do? Are there any seals or gaskets that should be replaced while doing this? How about special tools needed? I will be getting a manual soon hopefully. Thanks guys
Trent
Re: Greasing universals on Alpha1
You will need the gasket kit. Go to your NAPA autoparts store and order 18-2618. They can have it the next day. No shipping charges. Put the drive in foward.....Ah heck just read here and look at the pruddy pictures :) Use marine grease and you will be fine. You dont have to check alignment (but its a good thing if you have the tool)<br /><br /> Drive Removal
TooTired
Trent: thanks, this should help greatly :) . Anyone else have any advice?
TooTired
flashback
not much i can add, Trent is a guru on these alphas............good luck
