Re: Green Pool
Just for the record ,I've been maintaining a 25,000 gal pool for 21 years and can tell you staright up that all granulated chlorine is not created equal.I fully agree that sock it and other such products by HTH and such are an inert residue leaving clarifier requiring mess.The only chlorine I've used for 15 years going is Leslies chlorbriteII (99% sodium dichloro-s-triazinetrione dihydrate and 1% other)and it disolves readily and leaves an insignificant amount of detritis.One advantage gained from administering the chlorine via granules is the fact that you can target it to specific area and broadcast it around the perimeter of the pool shell where many times organic stains can collect.This gives it a chance to make direct contact to these areas at high ppm levels until the granules completely disipate.Again, this stuff I use doesn't even cloud on the way down.Good stuff.
As mentioned above,when your water goes green,you need to shock it up to 20-25 ppm to perform the needed initial burn out of the waterborn bacteria.Then let it lower to 1-3 ppm where it is maintained until a periodic shock is needed again due to rain,heavy swim load,lack of cholrine maintenance,etc...
Another benefit to the particular chlorine I use is that for several years going the pools ph and total alkalinity have been very stable and required little adjustment.
Algaecide products whose active ingredient is chelated copper sulfate have also proven to be the most effective at controlling and preventing the apppearance of green and brown film algae in our pool over the years.Just don't overkill on the stuff or the plaster can get a blue tinge.
