Grew Limited St170
wreckingball
Hello guys ,
I'm new to boating and don't really know all that much, I just bought an 1988 Grew and it has a 115 Mercury on it . The motor runs fine and is connected straight to the battery . My problem is that I have a nest of wiring for the boat ( lights , horn , pump and other accessories) and have no idea what is what . Does anyone have a wiring diagram for this boat ?
GA_Boater
Welcome aboard.
Your boat is probably suffering from 30 years of prior owners hacking and whacking, then adding stuff to the electrical system with no regard for common sense. :doh:
Wiring is wiring for the most part. I believe AllDodge or Scott Danforth has a generic wiring diagram for a boat, including color codes standards if PO's tried to keep things straight.
[h=2]American Boat and Yacht Council Standards[/h]
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
COLOR ITEM USE
alldodge
Howdy
In most cases it sometimes is best to rip it all out and start over, but in any case, wiring is generic. Get the motor wiring all cleaned up, then decide which is best for you and your budget.
Its best to run new Positive and Negative wires to feed anything that the motor does not need to run. Here is the generic wiring diagram. If you have any specific questions, fire away, will try to help
wreckingball
Thanks guys, is it bad that the only hooked up to a battery is the ground and power for the motor? have power trim and it is working aswell
alldodge
What you have is normal for most manufactures. They tap off the Red/Purple feeding the ignition to accessories. This does work so lang as there is only light loads. Not the best way but the cheapest
As for the trim, it is connected on the starter post so no need to change anything with it
