grey oil and water lower unit johnson 85esl73m
Dali30
How do you clean inside your lower units when water and oil is "mixed" together? i have now drained it as much as i can the normal way. first ting that hit me is to set air pressure on top hole, and let it blow out bottom oil-hole? diesel may work well to kind of flush inside lower unit as the sludge was nasty? k
oldcatamount
Re: grey oil and water lower unit johnson 85esl73m
If you are talking about the gear housing, a little diesel or kerosene will clean out the sludge pretty good.
Dali30
then i'll go for the diesel,had to check as i have never had problems with nasty sludge before now on all outboards i have owned. thanks.
iggyw1
Ensign
If you are getting grey oil and sludge in your gear box, you are getting water in there from somewhere. It will only get worse if you do not reseal things now. New seals, gaskets and 'O' rings are called for I believe.
Dali30
after looking closer at it,its not sludge but old oil and water. its light brown kind of. will change them seals with impeller and such. thanks.
iggyw1
Ensign
I am in the middle of changing my water pump currently. Waiting for the pump kit to come in. I will be changing my housing, impeller, gaskets, seals, 'o' rings etc. too. My kit for a 1965 75 h.p. Evinrude was $230 to $260 everywhere. I lucked out and found it on e-bay for $65 with shipping ( the entire kit with the right part number). Got lucky as the guy had two of them and I bought the last one. Would have bought both of them for the price if he still had both! Good luck getting yours all sealed so the sludge don't happen again.
amarcil77
Kind of glad I just found this thread. I have the same motor. Yesterday I changed my lower unit oil and found the same thing. Do you have the part number for that reseal kit. All I can find us the water pump kit
Dali30
all i can se on parts sites,is that few o-rings on gear shaft. Have to look into this today. I have heard that this 85esl73m need to be put in forward gear so that the lower unit will slide down? I tryed when engine in neutral,but the lower unit is stuck. I have remowed the total 6 screws but can be moved only about 2-3 millimeters. I dont remember where,but i stumbled over a text that stated it has to be in forward-gear to remove the unit. can someone confirm this?
Gear shift position does NOT matter on these at all.----------You have disconnected the shift rod behind the lower carburetor ?----5/8" wrench required to take out one bolt.
Bosunsmate
put a bolt back in, you dont want it hanging by the shift shaft bolt
Dali30
yes i disconnected the shift rod right below lower carb. It still does not separate more than 2-3 millimeters. i figured i try to start it and shift between gears,maybe its corroded and will loosen that way. then try to remove it.
Vic.S
I have a ? That's kinda on the same topic and sense I'm new to this board and can't figure out how to start a new thread I will just post it here. I have a 1973 50hp Johnson power shift2. What type of oil do I use in the lower unit? And where do I buy it at?
AFAIK it uses an SAE 80W/90 outboard engine gear oil ... (unless anyone says type C because it is a hydraulically assisted gear change)
You start new threads by going back to the board index, using the breadcrumb trail at the top of the page, and clicking on the "New topic" box.
It is bad form ( and against the rules) to high-jack old threads!
