grinding from neutral to reverse
laskopivo
Anyone know what adjustments i need to make to stop a grinding sound when i go from neutral to reverse?
rodbolt
Re: grinding from neutral to reverse
depends on who made the controls,the physical condition of the cable,the condition of the clutch and most important the HP and model number of the motor.
Silvertip
If you are taking your time going into reverse (or forward) you are adding undo wear on the clutch dogs. Snap it into forward or reverse when you shift.
chanice
first off check that you are in the correct neutral position / put the control lever in the neutral position then rotate the prop shaft (ignition off of course) \if you find any clicking either way then its not in the correct position, so disconect the gear shift cable and move the shift lever into the correct position
the shaft should rotate both ways with no clicks
now adjust the cable length to meet the shift lever ,then check both forward and reverse also check your idle revs if they are too low it will grate when engaging gear
