Grinding noise when going into neutral
UtahBoating
Have a 5.7 merc alpha one gen 2. First 5 times out no issues. Last outing I am getting a grinding noise when I go back to neutral from forward or reverse. I can go from neutral to gear with no issues. The grinding noise sounds like a starter grinding, not the typical shifting sound. In other words it is fast and high pitched. Any ideas where to start?
alldodge
Shift interrupter switch adjustment and check your gear lube for contamination
UtahBoating
Changing gear oil tomorrow for winterization. Will know at that point if contaminated. Thank you for the response.
