There was a post about this same problem over a year ago. But there was no suggestions so I'll explain my problem. It will shift into gear alright, however when I go back into neutral there is a grinding noise like it hasn't fully disengaged. It only seems to happen after the outboard is warm, I can't get it to grind when I have it hooked up to the water hose. If I lean the shifter to the reverse direction (in neutral position) The warning horn sounds. Hopefully it's just an adjustment issue. But which way do I adjust? Thank's for any suggestions.
