I have a VERY frustrating problem. I've looked through several pages in your forum, but didn't see a similar issue.<br /><br />I just bought a 1996 Chaparral that has a rebuilt 5.7L Mercruiser engine that only has about 10 hours of use on it with a Bravo III lower unit. On the way home from the previous owner's house, after going fine for about 30 minutes, the engine sputtered and died. After a lot of troubleshooting (and turning the engine over numerous times after adding gas thinking it had run out of gas) and then downloading the schematics, we found that there wasn't 12 volts across the coil. After checking the whole wiring system, we finally found tonight that it was the (-) that was lost. The idiots at the marina just screwed down the black lead from the ignition amplifier to some shiny painted metal, making the screw head and threads the only ground path. As soon as I tried to remove the screw, the head popped off. So, we connected everything back together and moved that ground point. That got my coil working.<br /> <br />Now, the problem. I tried to start the engine and it turned over for about 5-10 seconds and it did briefly try to fire. But, right after that, each time I tried to start the engine, moving the throttle a few time with the engine disengaged, it will turn over for a second and then make a loud metal-to-metal SCARY sound. Several times, after that short turn-over the engine would quit turning over. I switched one of the batteries out with a fresh one, but no change. I'm an Electrical Engineer so I could understand the circuiting, but this is VERY frustrating! The marina said I could have the boat towed all the way back to them, but it would be over a month before they could look at it. After seeing their wiring job, I don't want to take it back to them. Do you have any ideas what I can check or do? I'm sure that the other night, and tonight, the throttle was messed with multiple times because we thought the boat had run out of gas. Tonight, it sounded almost like the engine was getting engaged (I'm not sure; it just sounded bad!). The previous owner asked the marina to replace almost everything, and said he hadn't had a problem in the couple of times he took the new engine out. Any suggestions you could give would be GREATLY appreciated!<br /> <br />Thanks again!<br /> <br />Floyd
