i've brought this boat back from retirement,worked through most of the issues. now its making a little bit of a grindng sound when i go from neutral to forward or reverse. i had to adjust the throttle cables to get it to run. then found that the cable had came off the shifter/tilt and trim handle. now i have to work the handle a little to insure its all the way in nuetral to get it to start. its idling around 1500 rpms. i was wondering if the idle is to high and this may cause it to grind when going into gear. its an 88 ford 2.3 omc cobra.
