grinds in reverse 25 horse Merc '87
cts2
1987 Mercury 25 horse. When put in reverse at idle it is ok. As I up RPM's it starts grinding in lower unit like the gears are not fully engaged. Shift cables adjusted as far as they can go for reverse. Forward has no problem. Is there a linkage that will adjust to the lower unit or is it a worn/stripped gear?
Bear
Re: grinds in reverse 25 horse Merc '87
When did this all start? <br />Who changed the impeller last time?<br /><br />I think it can be adjusted in the linkage under the cowling. I cant see what it looks like where the shift shaft connects to the linkage. But it either there or in the linkage itself.<br />You said it is adjusted all the way you can, but is that just the shift cable, not the linkage?<br /><br />I suppose you have a manual start and tiller model. I have a 1987 8HP and it looks about the same. Never payed attention to the shift shaft and linkage connection when i did some adjustments a few months ago. My problem was it didn't open fully. There was something about a linkage that didn't move freely when going from reverse to forward. Some grinding, cleaning and lubing took care of that. <br /><br />Here is where I looked at your(?) model:<br /> http://www.dolleroffshore.com/parts.cfm?c=bt&m=1&pn=349&bn=274 <br /><br />Try again before you tear down the lower unit.<br /><br />Good luck!
