baytonemus
- Jun 23, 2010
- 217
I'm installing the salvaged wiring harness that I bought for my 40352D. Where is the heavy ground wire usually connected on that motor?
If I remember,it connected on the starter bracket,but any bolt should suffice as long as its not a head bolt or one that could cause a leaking condition.You can also get a replacement mounting bracket bolt ,that is longer by about 1/2 to 3/4 of an inch.then double nut ,one nut to hold the bracket ,the other with a lockwasher to accept and secure the cable.Im talking about the starter bracket mmounting bolt
