Hi All,
I have a 1970's Hourtson Glasscraft which has taken some abuse due to a terrible trailer the previous owner used to use. The keel has been ground down and there is some glass exposed. When I use the boat (yes I have still been using it) I get a fair amount of water in the bilge I am curious if it could be coming in from this area?
Anyways winter is here and the boat has been slipped away. I would really like to fix this up on my own so that it is structuraly safe, not exposed to the water and of course sealed. You can see in the two pictures the main area of concern. In the third picture there is some damage up high and when I look into the cutty I can see light coming through this area so that tells me it is very thin.
I have never done any fiberglass work before but I am mechanically inclined. Is this something one can do on their own or is it best to get a professional to do it since we are not talking about nicks and chips (I will get to those later) but the integrity of the hull. Where should I start? I have looked on my own but mostly found fiberglass chip repair walk throughs nothing regarding the keel itself. In addition the blue paint on the bottom of my hull always transfers to any skin/clothing it comes in contact with. Is there a reason it is constantly rubbing off? Again previous owner slapped a quick coat on before selling is there some form of sealer that should have been applied? Thanks for your advice.
