Ground wire on an aluminum boat
sberl
Hello all,
I'm restoring an aluminum boat and cannot seem to find an answer to my question. The diagram below is from the switch panel I purchased. Where should I connect the black (earth) wire to? To a negative terminal on the fuse block or attach it to something metal which is connected to the hull? Or is it neither of those two? Thanks in advance! Snap19.jpg
TyeeMan
Master Chief Petty Officer
The negative terminal on the fuse block should go directly to the battery so you could connect it to that. Or run a wire to the negative terminal on the battery.
Never, never connect any ground wires to the boat/chassis itself, you'll be in for all sorts of electrical headaches.
to expand on Tyee's comment of never
if you ground accessories to the hull of the boat, you can watch the boat literally disappear in a very short period of time as galvanic corrosion eats the hull.
sberl
Exactly what I was looking for. Thanks much guys!
