grounding during compression testing
cbourbeau32
Would clamping a jumper cable to the spark plug and then clamping the other end to an engine bolt be an effective way to ground the coil during compression testing?
Thanks, Charlie
Re: grounding during compression testing
No need to worry about grounding ignition on a 66 motor.
cbourbeau32
Ha! Racer, you knew what I was talking about. Thanks!
I have repaired these motors for many years.--Never had to worry about grounding the plugs.---Never saw a warning in factory manuals to do so either.
Chris1956
You can also jumper the starter solenoid, with the ign off. That works on all models.
