OK, another some more 'schoolboy' questions, sorry for the ramblings but I am slowly learning .....<br /><br />I've recently got myself a 15 foot fishing boat (pix here). I'm trying to figure out just what the hull may be made of. I am a complete novice at this (and spending much time browsing through the forum and getting to grips I think with the terminology!) and after tips on what I should be looking for. It is a single skin hull, with no obvious floatation. When I lift the floor boards the inside of the hull is spiders web of threads which I am assuming is fibreglass matting. This extends an inch or up the support struts (are they the stringers?) but appears to not be adhering in a few sections. The outside of the hull has been painted a couple of times.<br /><br />So here's the thing, the boat didn't cost me much and I don't want to spend much on it, and certainly am not too bothered with aesthetics. I am just keen to do what I can to give the whole underside of the hull a once over before I take it out. The boat has several layers of paint (not fresh which I would have been suspicious of) and the underside has clearly seen some use. I have found one area fairly central near the central runner that gives a bit to the touch so am assuming a crack (although no visible crack on the inside of the hull) and suspect that due to it's age the paint may be hiding more sins a once over coat of some sturdy coating would not go amiss over the whole of the underneath to waterproof any minor imperfections.<br /><br />So a plan could be:<br /><br />
- <br />
- Cut back loose fibreglass inside the hull, and relay some matting and resin then paint to rebond the stringers<br />
- Paint strip (Sanding or using fibreglass friendly remover) the underside, white parts in photos above<br />
- Place a section of matting and resin around the area of give on the underside<br />
- Then assuming I don't find any major defects give the whole of the underside a couple of layers of quality paint (any recomendations?). Will a few layers of paint be enough for small spider type / hairline cracking or should I use gel coat or any other products you could suggest??<br />
