GSM Low voltage alarm
bbjunkie
Hi,
I'm in the process of preparing my boat for it's 1st season in a marina since I took ownership.
For peace of mind, I would like to install some sort of low voltage alarm that would send me an SMS message if the battery voltage drops below a certain point (so I can get to it before the batteries are so flat they can't operate the automatic bilge pump)
Is there such a device on the market?
I could probably design/build something based on an Arduino board, but I'd rather have a tried and tested system.
Pete
Don S
Re: GSM Low voltage alarm
What motor?
If you have a volt meter and it shows less than 13 volts while running above 1500 rpm, you have a problem.
Hi,
Pete
i havent seen one. i have seen the ones that take a picture and ones that sense movement used for security so converting the interface to work on a voltage switch is feasible. If you have a brass bilge pump i would be more worried about someone stealing that than flat batteries as thats what happened to a friends boat that ended up sunk in lowestoft harbour. It would be intresting to see if you can get a wi-fi signal where the boat is located at the marina.
bbjunkie
A wifi signal.. good point, not sure - must check that out!
I found an alarm that does what I want and much much more, but it's prohibitively expensive, probably because of the other things it does.
To clarify, I want to monitor the voltage of my batteries while im not at the boat. Therefore whatever motor (Mercruiser 3.0LX) im using is irrelevant as the batteries will be at rest.
I will investigate wifi and see how that turns out, as it would be a cheaper way to run the system and may mean I could have all sorts of telemetry on request.
Thanks for the ideas
Pete
jhebert
Ensign
Look into the Arduino development system. You can probably make your own device using an Arduino. See
Arduino - HomePage
Your idea of using SMS to send the messages means your boat will need its own cellular telephone. You probably want to get a cellular modem, see
MultiModem? iCell Home Page
Don S
I misunderstood what you were looking for, so I am going to move this over to the non boating technical topics forum for the simple fact that what you are looking for is not a specifically marine product, just something you want to use on a boat.
tallcanadian
A GSM would work okay and monitor a low battery but with any cell dialer you have to get monitoring service from an alarm company for this to work. Now if you had a regular alarm panel and a phone line, then you would be okay.
MTboatguy
Why not install a solar charger, that will maintain the batteries? That is what I do with my RV and I have never had a problem.
