Re: GT 150 jet sizes not listed...
I checked also crbenny and Mr. D is right on.<br /><br />Bogging down at midrange could mean that one of the intermediate jets are plugged or at least partially plugged. Have you checked the sync and link? If the throttle plates are not coming open at the right time, this would cause the problem also.<br /><br />The orifice openings can be checked with wire drills of the correct size...ie...a 30 intermediate jet can be check with a wire drill of .030. The letters denote the thread size of the orifice.<br /><br />In my early dazes, I made a orifice remover from and old screw driver of near the correct size. Just filed it down till it fit.<br /><br />From another angle, have you checked the primer solenoid is not dumping fuel into the carb throats when it's not supposed to? You can check by pulling a primer hose off one of the carbs with the engine running. If it's spitting fuel, chech the primer solenoid red lever is pointing down to the bottom of the solenoid and that it is not energized.<br /><br />Also check for any recirc hose that may have pulled lose from a nipple or borken hoses. Fuel lines in good shape? None that are hard and need replaced, all connections tight?
