does anyone happen to have knowledge to whether or not the TFX marine guages will clip right up to my factory harnesses (OMC 4.3) or do I have to rewire the whole dang on thing? Thanks guys
The wires will be the same, but you may have different wire ends on the wiring harness. Depending on the gauge<br />Also, if the readings are way off, you may need a different sender to match the gauge.
