guages
supermotobaz
i have a 1981 merc 50 blueband pullstart i wanted to fit a tacho is there anyway to fit one and if so what rev range would i need, also what other guages could i fit I.E. temps or pressures cheers
rickdb1boat
Re: guages
Tach for any motor. Easy to install:<br /><br /> Tinytach.<br /><br /><br />You can put a Temp. gauge and a pressure gauge if you like. I would personally go with a pressure gauge..<br /><br />They are normally available here at i-boats, but they are out of stock. West Marine and others have the pressure gauge kits that come with everything you will need to hook it up...
