Don and Rodbolt are disqualified from answering this!
<br /><br />1997 Chaparral 2135 with a 5.7LX EFI GEN + Bravo 3. Winterized by me. Outdrive removed to grease u-joints, change oil, change annodes, and repaint.<br /><br />Put it in the water (by myself), tied it to the fuel dock, parked truck/trailer.<br />Came back, started boat. Pushed away, put it in gear & made hard left hand turn to go towards my slip. Decided that I was going a little too fast (cold idle & 26" props make for high idle speed). Pull back on lever, to neutral and...<br />Nothing happened, boat kept going forward in gear. Tried reverse, and it just went faster in forward. So in order to slow down, I had to turn off the engine. Then if I wanted to go forward again, I had to restart the engine... in gear! Let me tell ya, hard to pull into a 12' wide slip with no reverse!<br /><br />So, all my fellows boaters do you know what the problem was? And here's a hint it was my stupidity?
