Guest battery isolator ?
salvageyard saviour
I'm electrically illiterate. Here's my stupid question.
Boat is a 68 Penn Yan with 210 hp OMC
70 amp Arco alternator
Has a Guest switch 2111 and isolator 2401.
I only have 1 battery installed.
Will I hurt the isolator or alternator running it?
The reason I want to keep it capable of 2 batteries is I'll buy 2 new batteries when I finish installing 4 electric downrigggers.
As I've been working on it, the switch and isolator are disconnected and bypassed.
When I finish the downriggger wiring I want to put everything back correctly so I can button up the stern.
Will I always have to have 2 batteries?
dingbat
The short answer is no
Simply one input with a switch to direct current to one or both outputs.
the 2401 isolator is nothing more than a bunch of big diodes.
salvageyard saviour
The diodes confuse me.
Will they or the alternator over heat without the second battery?
The alternator is a 1 wire
I think a newer acr will "sense " no voltage and not charge that output, but I don't think diodes are that smart.
no, they wont. however your one-wire alternator will drain your battery unless you turn the batteries off every time. that is why one-wire alternators are not used on boats
