Jestertattoo
- Jun 4, 2012
- 10
Oh boy where to start. The skinny. 1989 4.3 liter Mercruiser, Alpha 1 Drive. The boat is a 1989 18ft bluewater open bow. I got this boat from a friend who no longer could handle the pressure of putting it in the water. Long story really.
The journey begins. we got the boat and had lots of fun in it for the first year. then life got busy and the boat sat. covered and winterized when the weather got cold. boat sat for about 1 1/2 years. summerized and winterized. so this year time to summerize and get back to having fun. the boat just would not start.
Investigation. not getting fuel. i started with the fuel pump, it was bad. the pump was original and internally was filled with mud. my thoughts lacquered up old gas that got new gas and turned to mud.
I trolled the forums and did my research..
1) I replaced the fuel pump with a new pump,
2) I emptied the old gas out of tank
3) added fuel water seperator
4) added new fuel line
5) replaced carb inlet screen filter
6) tried to start again. Failed!!
still no gas to carb. starts with starting fluid but not getting gas. I troll the forums and I did my research. time to rebuild Carburetor.
The carburetor is a 2GC rochester 2 barrel with a stamp of 3304-9565. i purchased rebuild kit and new float. watched several videos and I rebuild and adjusted carb. Put everything back together and and turned the key after a few cranks it started.
After starting it is idling really rough and billowing BLACK smoke with a carbon residue out of the exhaust.. once again i trolled and found instructions for dialing in the carb. i tried everything. still no change. out of frustration i went to my local boat repair shop, to schedule a time to drop it off. they charge $ 120.00 an hour to diagnose or screw me out of money. not to mention they cant look at for 4 weeks. initially their thoughts are just a bad carb. Timing, Compression. So here I am seeking advise. I just do not want to take it in when i can do the work my self just need the proper guidance.
1) is this a fuel issue? where do i start. Compression test? Timing? all of the mentioned.
2) what carb should i put on it, what other options are there besides Rochester. I have read a lot of mixed reviews not many Rochester fans. but after all the research Rochester is the main one that keeps popping up to put back on it.
Thank you in advance, I enjoy reading every ones journeys about the hull in the water to throw money into.
Don
Don
