Last night I pulled the cylinder cover water jackets for inspection....<br /><br />Most all the bolts came out easily, but a few were tight and after removal contained some aluminum on the bolt threads (only a few threads contained aluminum)... Obviously a result of seizure.. So now a have a few holes that have "slightly stripped" threads.<br />I'm planning on tapping the holes with the current thread size to clean out and try that. I think it will work due to the low torque required for the water jackets..<br /><br />But I wanted you're thoughts, and also any recommended anti-sieze that will work for a steel bolt going into aluminum...<br /><br />Motor below...
