Re: Gun the engine to get idle down at start
I'm not entirely sure if you mean it will stall if you don't or if it idles high until you do that. If it idles high maybe the throttle linkage or choke plate is sticking a bit. Just spray the hinge points with some PB blaster and try again. If it stalls unless you do that, maybe the choke is staying on too long or is it running a bit lean (back of the fuel mixture screw a 1/4-1/2 turn). Running lean can also make it idle a but faster than normal when cold, so that may be the same issue if it idles too high (but only if it doesn't idle high when warm).
With carbs, the rules tend to change by engine and carb setup, but those are my general tips. Let us know how it goes and what fixes it.
