MTboatguy
- Jul 8, 2010
- 8,988
Here it is Labor Day Weekend and I started this on Memorial day weekend...
1973 Evinrude 50 HP motor that ran good when I parked the boat last fall, pulled it out can't get it to run, no spark..
I have tried 2, not 1 but 2 power packs on it now, still no fire, I pulled both coils off today and they seem to test out fine, they do have 1 small crack on the green plastic insulation, but not major cracks, just hairlines, my coils on my other motors have much worse cracks and run fine.
Nothing looks bad under the flywheel that I can see without removing it, I will probably remove it in the next day so I can see better. The fuse on the engine is fine, I have tried with the black/yellow disconnected, no change, still no fire...
So I am really at a loss to which direction to go next, the only thing I have done to this boat since I got it was hook a tach up on it and when I am cranking it over, the tach seems to be moving. The battery is at full charge, I pulled the starter, took it apart to check everything and it is fine and turns the engine over with enough RPM's that is should start. The only other thing I can think of is the ignition switch in the remote has gone bad..
If you have any ideas I am not thinking of please let me know.because I am now playing wiffle ball and I am losing. Lots of strikes and no hits.
thanks.
thanks.
