h2o in lower unit oil Merc 7.5 1970
hallhen
Serial numeber 2813417<br />Also, there is oil in prop nut area and test tank.<br /><br />Can a bad oil seal cause this problem?<br />Where can i get an inexspensive pressure test tool?<br />What is the best a way to flush the lower unit with out removing the prop. barings?
Fouled Plug
Ensign
Re: h2o in lower unit oil Merc 7.5 1970
A bad seal will let water into the lower unit, causing the fluid to look like a chocolate shake. Did you try a fluid change with new vent/fill screw seals? Some unburnt oil from combustion will appear around the prop and in the water...is it LU lube for sure?
hallhen
Not sure if it is lower unit oil. <br /><br />I replaced the fill seal but the vent screw does not require a seal according to the parts list.<br /><br />The motor sat for 15 years and i am just getting it going again.
