h2o pump Q
fishinAK
So if my over heat horn is going off, but I still have a steady "pee" stream Could my h2o pump still need replacing?<br /> I mean if it is peeing the pump is working righ?<br /> ...oh ya 1996 Johnson 50 hp ob
Goodoleboy
Re: h2o pump Q
Yes it means your water pump is working. Water comeing out of the telltale does not go thru the thermostat.<br /><br />You may have water blockage in motor. Or you may have T Stat that is stuck closed.
