Been There
- Mar 9, 2019
- 25
You know something will probably happen when the day is sunny, warm, and no wind to blow you off the lake. That was the case today, only there is a minor flaw just about to happen.
I launched the boat, trolling across the lake and about in the middle (1/4 mile from shore) the trolling motor quit. BAM!. no 12 volts. Checked the circuit breaker and it was good.. However, the plug from the trolling motor cable was HOT. In fact it was melting the plastic connectors. Dead in the water as they say... so it becomes paddling time, and back to the dock and ramp I paddle for what seems half hour. Which means boat back on trailer and head home to find the melting cable plugs.
It appears the new just purchase "Anderson SB50 Quick Connect 6 guage battery plug connector was a waste of money.
I knew I had a spare Twist Lock setup, so I wired that all us and run the trolling motor at 5 speeds for half hour and no hot wiring to be found. I would guess the Anderson SB50 plugs was faulty.
Tomorrow, back on the lake. With cross fingers.
