Hail Joe Reeves
RC Wilkins
The fluid lockup was it.Thank you very much.Now can I ask you one more thing?I have spent 2 cycle oil dripping out of the two exhaust ports and from somewhere up around the under side of the power head.This runs down the front of the lower half of the motor.<br />Thanks<br />Bob
walleyehed
Re: Hail Joe Reeves
I'm not Joe, but what you are noticing is fairly normal.....both of my 115's do it too, and I noticed last week my neihbor's 100hp Jav. was oily on the front of the mid-section as well. <br /> I guess a guy might want to check the carb silencer box drain and make sure the hose is connected at the bottom of intake box and on the nipple on the front lower section of the crancase....if that hose comes off, everything that splatters around out of the carbs dumps when you trim or tilt up, insted of being scavenged thru the case...... :rolleyes:
