Hailing JasonJ
AK_Chappy
I know you used to be an exterminator.<br />I have a question. We have LOTS of tiny ants, someone said they were sugar ants, in our area. With the EXTREME COLD of Northern CA (about 50F) and the rain, they are looking for food inside our house and building at work. What are some successful stopping agents to use. I don't want to put down a lot of pesticide. I have a dog and two cats to worry about also. I can't put down stuff along the outside of the house (rainy season) also due to the crawlspace is a dirt floor. The house is about 50 years old and has LOTS of entries for the ants. It also belongs to the AF, so I can't make major changes.<br /><br />I have heard that baking soda or cinammon works, but was curious. Any ideas??<br /><br />AK Chappy
Re: Hailing JasonJ
Might try posting that in the non boat tech side.<br />Gets moved around to quick here.<br />.02
AK_Chappy
Re: Hailing JasonJ
Thanks Link.<br />Not a bad suggestion.<br /><br />Mods,<br />Could you move this thread?<br /><br />AK Chappy
Twidget
Re: Hailing JasonJ
If they are pharoah ants(little buggers that do the line dance :) ), you can get little poison traps at Lowes/Home Depot. Just put them close to the line, they will take the poison home and the trouble will end.
AK_Chappy
Re: Hailing JasonJ
Twidget,<br />That seems to work on a temporary basis, but they tend to come back not long after.<br /><br />And yes, they do the line dance as you call it.<br /><br />AK Chappy
AK_Chappy
Re: Hailing JasonJ
LMAO at alden!!!!<br /><br />jsfinn, not sure that would work. I think they are coming up from below the house. I ain't a going under there, too many black widow spiders!!! I hate them things.<br /><br />I put out some ant baits here inside and so far it seems to have helped. We ziploc bag anything that has been opened. They haven't discovered the kitchen cabinets yet. Thank goodness for that. The baits seem to have done their job.<br /><br />AK Chappy
JasonJ
Re: Hailing JasonJ
Believe it or not, there is a product called Taro that works pretty good for these ants. They are most likely Odorous House Ants. You can tell by picking some up and crushing them. There will be a faint rotting coconut smell. <br /><br />Taro is basically a borate mixed with a sweet attractant. You could make some yourself by mixing a sugary paste with boric acid, but you mave to be really careful. The whole point of it is to ensure they take it back to the nest and transfer it to other ants. The chemical dosage has to be so low that it has been transfered several times by the time the initial ants die. this is why is is better to use commercial products like Taro, or call a pro. There are some proffesional baits that worked pretty good for me.<br /><br />One thing about spraying chemical is you may stop seeing them, but it doesn't mean they have gone away. they are very sensative to chemical and will avoid it. Also, you can have a colony in the house with several hundred thousand individuals with several queens, it is next to impossible to eliminate them with spraying. I used to also gas the colony if I found it, but that was rare. If you can deterime that they are coming from the outside, the entire building and all access points to the building would need to be sprayed. that includes powerlines, tree branches, all of it.<br /><br />The most important thing of all is to eliminate what is attracting them. No honey pots, crumbs, sweet residue, none of it. I have solved a lot of problems just by telling the customer to get rid ot the sweets or keep it in the refrigerator. Sometimes they are attracted to the sinks in search of moisture. this is more difficult to manage, but eliminating wet sponges, dishrags, keeping the sinks dry. <br /><br />They were probably the most difficult pests we had to deal with. The rest were much easier. I would rather have had a roach job than an Odorous House Ant job. Good luck...
AK_Chappy
Re: Hailing JasonJ
Thanks Jason!!<br /><br />It's Ok Techno, he can go back to being a cop now :D <br /><br />We did clean out all the sweet stuff and that seems to have helped. Just frustrating to think you got em cleaned out and then my rugrats will spill some kool aid on the table and just leave it. I get home and there would be ants all over it, grrrrr.<br /><br />Haven't seen any for a couple of days now, though so we will keep our fingers crossed.<br /><br />AK Chappy
D
DJ
Guest
Re: Hailing JasonJ
JasonJ is now out controlling other types of pests.<br /> ;) :D
