I have a 1979 Chrysler 55 hp outboard on a 1984 Aero-Glas Phantom. The motor runs in neutral just fine. I've replaced both coils & plugs. Carb has been rebuilt. It purrs and runs great throughout the band when in neutral. When under power in either forward or reverse it runs horrible... won't plane out at all. It's going through 6 gals of fuel mixture (50:1) in about an hour. Then, just as it's running out of fuel it comes to life... runs like crazy... planes out instantly and then dies from lack of fuel.
I've read a bunch of the other articles on here but haven't seen anything quite like this one. I can only assume that it's something with the linkage. I'm a newb out outboards. I've rebuilt 4-stroke motors, worked on turbine engines, rebuilt all kinds of two-stroke motors... I'm baffled. I've had it to two different shops... got gouged pretty good by the first one whom swore it would be just fine. The second guy ran the motor with the lower in a horse trough. Neither one put the boat in the water and ran it under power.
In my inexperienced outboard mind, something in the linkage is causing it to run super rich.
Any thoughts?
Tom
Any thoughts?
Tom
