Hand rail hardware needed
Jim Lahey
I am restoring a 1974 Glastron V156 tri-hull.
I've searched over the internet and eBay. I am looking for close to original replacement rail base fitting. The countersink holes have worn.
I believe it to be 60 degree. It is on a 1974 Glastron V156 tri-hull. I think many models will have the same fitting.
Anyone out there have an idea where to find one?
Thanks.
JimS123
60 deg. rail fittings like that are readily available, both on chrome and polished SS. However, you probably won't find them with the same bolt hole pattern.
Most today are 4-bolts. If you find some that are bigger and will cover the old footprint, be careful if screwing them in because if not bolted the strength may suffer.
Grub54891
Them holes don't look sunk. The screws are way to small. Just get the right sized screws/bolts.
