Hand tested compression results.
stant1man
I put the compression tester on each cylinder and got between 95-100 psi on each cylinder by putting a ratchet on the flywheel nut and spinning it round. Is this result good or bad?
Laddies
Banned
Re: Hand tested compression results.
Yes, that kind of a test does not spin the engine a speed, so for that kind of reading the compress is good, inless the engine is loaded with storage oil--Bob
