Hard pontoons for Zodiac
Kencryst
I have a 19' Zodiac. The pontoons are trashed and just won't hold air long enough to really have any fun. Does anyone have any idea where to get the hard pontoons like the ones the Coast Guard are using now on their boats? I've spent a couple of grand trying to repair the ones that I have and I give up.
Sea Rider
Re: Hard pontoons for Zodiac
As last chance have you tried Inflatable Sealant & Liquid Rubber application on tubes ? Those hard tubes must be very expensive, how about going for a complete thick hypalon or pvc retubbing ?
Happy Boating
TrygWes
If you want to consider a somewhat zaney alternate, there is the two part urethane foam which is used for floatation in the cavities of many/most boats. It is defined as closed cell so it is not suppose to absorb water. I used it when replacing the stringers and deck in an old Reinell cabin cruiser. The stuff is kind of messy to work with but it expands 30 times in volume when used at 75 degrees F. Fiberglass Supply ( www.fiberglasssupply.com ) in Burlington, WA was where I bought my chems. The 2 pound density stuff is remarkably strong and it is POWERFUL!! You would want to very carefully calculate the volumes of each chamber before mixixng and filling. You only get 45 seconds after mixixng before the stuff takes off and it does just that!! I reccomend wearing old throw away clothes and having a fresh box of latex gloves sitting next to your full roll of paper towels. There is a commercial alternative. Local boat builders should have an automatic mixixng machine and could use their equipment to inject it down into the tubes. Some spray on insulation contractors use very similar equipment. You will end up with the same old tubes but they will never leak air again. Contrary to the stated claims, it can absorb water over time and you will need to maintain the tube fabric to avoid intrusion.
Kencryst
I have tried a product that was recommended by a local shop. It was a two part epoxy that is made to repair hypalon tubes. I sanded the pontoons and applied the stuff on a warm sunny day. It lasted for about 6 months and then peeled off. I was actually thinking about just injecting the tubes with "Great Stuff." It's the expanding foam insulation that is used around doors and windows. Think I will look into the stuff you got at Fiberglass Supply TrygWes. I live in Seattle so a trip to Burlington is not a big deal. Thanks for the advice.
