Hard pulling to right
SpinnerBait_Nut
Ok, just got this boat and took it out yesterday for the first time.<br /><br />It is a 18' ebbtide dyna trak 179 bass boat.<br /><br />It is powered by a 150 Mag2 Mariner on a jack plate.<br /><br />It will come up on plane with n/p, but after it does, it feels like it wants to pull to the right.<br />Upon more thottle, it does and gets worse the more you trim it.<br /><br />The boat runs out at about 62 but it has this strange pulling to the right problem.<br /><br />Is this the trim tab adjusted wrong?<br /><br />Any other ideas?<br /><br />I have not adjusted the jack plate any. Just left it where they had it set cause I figure they had it set to run right.<br />Thanks.
JasonJ
Re: Hard pulling to right
Sounds like the tab to me. It was the same way on my rig, and 1/8 inch of a turn in the direction it wanted to pull to fixed it right up. You have to adjust in tiny movements, it doesn't take much to fix it.
SpinnerBait_Nut
Thanks Jason, but after closer inspection, they have removed this one to accomadate the quicksilver 24P prop.<br />It would hit it I would say.
ob
Dang,SBN 62 mph is moving out.We may need to change your screen name to S peed B oat N ut.
