Mercruiser, 1993,3.0, After I run boat for about 20 to 30 min the shifting between neutral forward and reverse gets very hard. When the boat is cold the shifting works fine. Lower oil level is good and lube is new. Any help? Thanks..
About the idle, I got the boat late last season and I don't remember what the idle was. I have the lower unit off changing the waterpump so I cant start today and see. I take it if the idle is to high this will affect shifting? I didn't think of that. At what rpm will this effect shifting, and what rpm should idle be st? Thanks..? Also I will check the cable.
