have a '98 90ELPTO. Hard start yesterday at the launch and has had a accelleration hesitation when getting out of the hole last few outings.
My normal proceedure in starting is as follows; I push the "throttle only" button on the quick silver throttle control and throttle up about half way. Then turn the key and push to choke repeatedly until it fires then back off the throttle when it starts to a "warm up" idle speed.
well yesterday it took a while to get it to fire and when it finally started it ran at a normal low idle for a few seconds (with the throttle lever advanced) before it reved up to a faster rpms. usually i have to back off the throttle imediately (to the warm up speed) to keep it from reving too high...it took a lot longer for the rpms to speed up in other words.
Im wondering if this is related to the other issue which is the hesitsation on coming out of the hole.
Once i get the boat at full throttle and the engine warmed up, it starts easy but the hesitation is still present out of the whole. Runs fine at trolling speed, crusing speed and WOT.
Compression is strong and even...have not done a spark test...plugs are about 15 months old. Any thoughts? Thanks
