enginesilo
- Jun 9, 2008
- 355
So my boat has been having some issues starting for the last few times I went out. If I turn the key I hear a click but the starter doesn't engage at all. After turning it a few times it eventually spins like normal and starts right up. However, last 2 times I was out, after being anchored for an hour or two and attempted to start the boat the starter itself turned over fine, but it turned over a bunch and didn't actually start the motor. What's really wacky is that the RPM gauge went backwards. Instead of going to let's say 1500 rpm's, it went in the negative. After cranking for a 10 seconds or so 2 times with a break, it then started normal and ran as expected like nothing was wrong. Once I got back to the dock I turned it off and on a few times and it started up without hesitation or no issues.
The motor is a 2005 Mercruiser 3.0L
So here is what I'm faced with:
-When you turn the key I hear a tick but it doesn't engage or spin the starter, but eventually after turning it off and on a few times it starts the boat like normal
-2 times I was out anchored, and upon restarting the boat the engine spun over a bunch before starting and the RPM gauge was going backwards while starting and spinning over, but once the boat started the gauge returned to normal readings.
Could this be a ground issue? The starter starts like a champ when it spins over, but I do hear the clicking so i'm wondering if that could be a solenoid of some sort. The backwards RPM issues has my mind boggled I never saw anything like this, but I do know RPM gauges work on a pulse or current so it could be some type of interference or ground issue.
Any ideas?
Any ideas?
