I have a 1973 mercury outboard, 115 hp. I have had in the shop several times for diagnostics. They say compression is fine and apparently the carburetors are OK. When it runs, it runs very well. It has clean, fresh gas in it. Last year I ran carburetor cleaner through it myself. However, after one day of use the spark plugs show different degrees of combustion. Some are clean, some are fouled. I clean them off prior to running the boat. Sometimes this helps, sometimes I need ether to get the thing to start. At the end of the day, it gets harder and harder to start and keep running. It finally ran the battery down I cranked it so much. Does this engine have a distributor like an old car? Could it need a rotor or points?<br /><br />Thanks ahead of time,<br /><br />Frank
